06-27-2023 07:54 PM
The previous owner is deceased and I bought the house and the doorbell is wired and mounted. I followed the videos and steps to unmount the doorbell so I could reset it but it's stuck. I can't call anyone for technical support because apparently there is no technical support number. How do I reset this doorbell?!?!
06-28-2023 06:56 AM
You need to factory reset, as you already found out.
Did you try using the tool to get it from the bracket?
If not, you could try using a small flat head screwdriver.
06-28-2023 03:44 AM
Good luck from my experience with google products you might as well throw it in the garbage
06-28-2023 06:56 AM
06-28-2023 07:24 AM
Yes, I did. As I stated. It's stuck. It will not pop off no matter what I stick in that hole!!!
06-28-2023 07:59 AM
To reach Support, you need to start with this link:
06-28-2023 08:09 AM
I have done that was well and have yet to receive a response
06-28-2023 07:51 PM
Hi Pissedoffangel,
Thanks for posting. I apologize for the inconvenience — let's get this sorted out.
If you are in the US, you can contact our installation partner, OnTech, to help you unmount and set up the Nest doorbell.
For all other countries, you can book an appointment with a Nest Pro. More information here.
I appreciate the help, RXShorty and MplsCustomer.
Lance
06-28-2023 07:53 PM
Thank you, I will try that
06-29-2023 12:07 PM
Hello Pissedoffangel,
Sounds like a plan! Let me know if you still need any help.
Lance
06-30-2023 08:22 AM
Closing the loop. Ontech is very expensive 200 Dollars for a service call, and once again offers no phone number to talk to a live person. I finally pried the **bleep** thing off with a screw driver.
07-04-2023 11:26 AM
I appreciate your help, @RXShorty, @MplsCustomer, and Lance.
@Pissedoffangel and @Anonymous, I'm sorry for the trouble this has caused you. As per your request to speak to a live person, please visit the link provided by MplsCustomer above, as it will help you to get support over the phone.
07-07-2023 02:20 PM
I just wanted to follow up to see if you still need our help. Please let us know, as we would be happy to answer any questions you may have.
Juni
07-08-2023 02:21 PM
Hello there,
Just checking in to make sure that you saw our responses. I'll be locking this thread if we don't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Juni
