Problem connecting to cloud
MahmoodAlhakeem
I cannot connect the camera with the Google Home  .. I get a message (Problem connecting to cloud) The solution from you will make me happy .. Thank you
@MahmoodAlhakeem
It sounds like this may be a situation that had to do with your home internet connection. Do you have the option to switch your connection from 2.4ghz to 5ghz, or vice versa?
12 REPLIES 12
I am terribly sorry to hear that you're having this issue! I would love to assist you with this issue. If you are having issues with your Nest Cam or Nest Doorbell, I would suggest that you first start by restarting it.
Restart: Keeps all your settings, and it should reconnect to the same Wi-Fi network. This is helpful if it ever becomes frozen, has trouble reconnecting to the internet, or isn't working normally.
I already did these steps.. but nothing changed
 I still can't connect the Nest Cam 😞
@MahmoodAlhakeem
Have you had a chance to reach out to Support about this as well? It sounds like it could be tied to your personal wifi. Are you connecting it to a 2.4ghz channel?
I am terribly sorry to hear that you're having this issue! I would love to assist you with this issue. If you are having issues with your Nest Cam or Nest Doorbell, I would suggest that you try to Factory Reset the device. Let me know if that works!
Best regard,
Just checking in on this thread and the activity on it. We'll leave this topic open for another 24 hours in case there are any follow up questions or comments.
SteveT1
I appreciate the help @Brad. Checking in to see if you have further concerns about your Nest camera? Feel free to update this thread, and we're happy to assist you further.
Steve
Martin681
I have the same "Cannot connect to cloud" problem with my new Google Nest Cam (battery) that I cannot get to work. I have spent an hour with Google support but no progress and they do not respond to followup questions to the ticket. It works when setting it up in the Wifi at my friends house. I have a Nest Mini and a lot of other stuff that works without problem in my home wifi (Ubiquiti Unifi AP; use the same SSID for 2.4G and 5G).
@Martin681
I am sorry to hear that you are still having this issue! It sounds like this may be a trending issue. Right now, I do not have a solution but we are still looking into this at this time.
BrutusGulin
I have the exact same issue with both a battery doorbell and outdoor camera. I have Google Nest wifi at home but when I try to setup the new devices the home app says I need to create a Nest Network and then I get "Problem connecting to cloud Please try again later." I have been trying over a period of 2-3 weeks so I doubt it is a server issue. Would appreciate any advice or tips. I have several working google speakers + hub max so very confused as to why this is happening.
Thank you.
Brutus
MahmoodAlhakeem
@MahmoodAlhakeem
