Quiero un plan para el ańo completo
Jorgejaquez
2 REPLIES 2
Jdauria
You can purchase an annual plan in with Nest Aware
ciprianocoche
Hi @Jorgejaquez,
Thank you for reaching out to the Google Nest Community team! Help is here; I'll do my best to find a solution for you.
As you want a year subscription for your cameras, there are two scenarios depending on your situation:
  1. If you haven’t migrated your 1st Gen devices, you’ll have to migrate your Nest account to a Google account it in order to get the 2nd Gen Nest Aware subscription.
  2. If you have 2nd Gen devices, then you can follow the next steps in order to get the one-year subscription:
    • Go to the Google Store and sign into your Google account.
    • Select Your subscription.
    • Under "Available subscriptions," find "Nest Aware" and select Get Started.
    • Find the home you want to add to Nest Aware and select Get Started.
    • To set up your Nest Aware subscription, follow the on-screen steps.
    • Your subscription will start after your $0 trial ends or within 24 hours if your trial has already ended.
For more help, learn about how to buy and manage your Nest Aware subscription.
Please feel free to let me know once you're done. Additionally thanks @Jdauria for the help provided!
Jonathan
