Realign nest door bell camera
Coach2
My camera was working fine I could see everyone coming and going to my front door. Now all of a sudden my angle has shifted to the left and now I can’t see people’s faces when they arrive at the door. Now I see a lot lower angle and to the left of its original position. Is there anything I can do to help get it back to the proper angle that I started with.
@Coach2
Your post says you have a "Nest Doorbell (wired Gen 2)" with the "Google Home app (iOS)". If you had the older Google Nest Hello Doorbell in the Google Nest app, the cause might be you inadvertently set the "zoom/enhance" feature, and can simply unzoom it:
https://support.google.com/googlenest/answer/9251364
@Coach2
