Rear out sude camera say empty battery
Tyson990
My rear out side camera states battery empty
gmelanymelissa
Hi @Tyson990,
Thanks for posting here in the community. I'm sorry to hear your Nest Cam says empty battery. I'm happy to help!
To better understand the situation, I'd like to ask a few questions:
  • What kind of Nest camera do you have?
    • Is it 1Gen or 2Gen?
  • When did the inconvenience start?
  • Are you able to check the camera feed?
  • When was the last time you charged your Nest cam?
In the meantime, let's check a few things:
  • Please keep the camera connected to the charger until its battery is full. The battery takes approximately 5 hours to fully charge. Refer to this article: Battery charge time.
  • Inspect the charging port and make sure there are no obstructions or damage to the charging port.
  • Ensure you are using the provided cable and adapter that came with the device.
  • Ensure the camera is securely connected to its power source.
  • Temperature: Extreme temperatures can affect battery performance. If it's very cold or hot, try relocating the camera to a more temperature-controlled area.
Keep me posted.
Melany
gmelanymelissa
Hi @Tyson990,
Keep me posted.
Melany
