Replacement Base Plate
DAMM72
Hi!
I need a replacement base plate for my nest doorbell battery.
Is there a way that I can purchase another one?
Thanks!
2 REPLIES 2
Thank you for your patience. We do not process these requests in the Nest Community Forums. If you are seeking a replacement, please note that unless the device is under warranty, we cannot issue a replacement.
Please first fill out this form so Support can collect some important information from you. Once the form is submitted, you will have your case number.
