Replacement Wall Plate for Google Nest Doorbell
CCAM
Hi.  I recently installed my Nest Hello Doorbell (wired) and the top clip for the wall plate appears broken.  I do not believe it is cosmetic more a concern about the doorbell not being secured properly due to the top clip being broken. The doorbell is not being securely held. Is there a place to obtain a new wall plate to make sure the doorbell does not get taken off?
Hey there, CCAM.
I apologize for my late response and thank you for all of your patience while waiting for a reply. I can definitely understand how frustrating your situation must be, but I wanted to make sure that your issue was addressed. Could you confirm if this is a brand new device, or if this is a brand new device? Did the clip arrive damaged or missing? If you have a case number, could you please provide it so we can look into this issue further for you.
CCAM
This is a brand new device.  I purchased it around July 2021, but only opened/installed it on Tuesday of this week.  The top clip appears to be damaged as if it is not the entire piece.  I do not know what case number you are referring to.
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
