Replacement cable / USB plug for Google Nest Cam (wired)
BradW
I've got a damaged cable on my new Nest Wired Indoor camera (the USB plug stopped working after some damage) so I need to replace the cable on the camera (or wire a new USB port on the end of the existing cable...)
Is there any way to get a replacement cable? Or wiring info for a the USB port?
Thanks!!
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
