Showing Live Camera Feed on Smart Display
mb771
trying to get my camera feed setup so I can view on my smart display in kitchen, but its proving difficult.
Before I could just right click and copy the URL and it worked fine - but new camera that option is very hard to find.
@mb771
Unfortunately, the 2nd gen Google Nest cameras and doorbells that get installed in the Google Home app do NOT have the ability to share their video stream with a public or private link:
https://support.google.com/googlenest/answer/9227530
If your smart display is a Nest Hub or Nest Hub Max that is in the same Google Nest "home/structure" on the same Google Account, you should be able to access your camera's livestream by selecting your camera.
That’s really unfortunate - I just installed 2 new floodlight cams and a camera with the intent of displaying them like the old one 😕 why remove features?  Not. Happy customer right now
@mb771
There are numerous other Nest app features that are missing in 2nd gen cameras and doorbells:
https://support.google.com/googlenest/answer/13038234#zippy=%2Cnest-app-only-features
So we're still using the Google Nest app for all of our 1st gen cameras and doorbells.
