Solar could you tell me if there is an external spot light camera that is compatible with adt?
deborahmcglone
  • Good evening
  • Could you tell me if your company has an external solar powered camera with a spot light?
Thank you
zoeuvre
Hi deborahmcglone
Thanks for posting here in the Community forum and for showing interest in our Nest Cameras. The Wasserstein Solar Panel is a high-efficiency solar panel designed to charge your Nest Camera with just a few hours of sunlight. It has zero downtime and a 360-degree rotatable mount for maximum sunlight exposure. The panel is easy to install, with a toolkit, 13ft cable, and easy-to-follow instructions. It has passed the Made for Google certification, ensuring 100% compatibility with Google Nest Devices. The panel is made by Google's leading accessory partner.
With sufficient direct sunlight, the Wasserstein Solar Panel trickle charges your Google Nest Camera (outdoor or indoor, battery) and the camera runs off the battery charge. At temperatures between -4°F (-20°C) and 32°F (0°C), the camera will continue to work, but the battery will drain because it can’t be charged in below freezing temperatures. If the battery drains completely, the camera will shut down and it will need to be brought indoors for it to charge again.
Let us know if that helps.
