10-17-2023 09:41 PM - edited 10-17-2023 09:45 PM
I have a total of (13) Nest Cameras, which consist of (1) Hello, (3) Floodlight Cams, (6) Battery Cams, and (3) Indoor Wired Cams. Most of these are located outside of my house, except the (3) Inddor Cams. I'm having difficulty getting a good connection to some of my exterior cameras, which are currently set to the 5GHz band. As a result, I'm thinking about switching all of my Nest Cams to the 2.4GHz band. Before I do, I have a few questions.
Thank you in advance for your help.
10-18-2023 03:05 AM
Here's the answers you're looking for:
Hope this helps!
10-18-2023 07:52 AM
@David_K , thank you for the info. Out of curiosity, can I expect better Nest Camera performance if I connect them via the 5 GHz band?
10-19-2023 02:07 AM
Potentially as the 5 GHz is likely to be less congested than the 2.4 GHz band, but again it depends on so many different factors so your mileage may vary.
