There needs to be a way to seamlessly reconnect to a new Wi-Fi network, without scanning QR code !
Samdaman904
There needs to be a way to seamlessly be able to reconnect all of the nest cameras and nest devices without resetting them and losing data. There must be some type of update for the whole entire system, in order to make the process to reconnect all of the nest devices to a new network to a new wireless router, without having to go through the tedious process of getting on the ladder and going outside and manually working on every single camera, that is on my home because there are too many to count. There needs to be an update in order to make it seamless without you having to leave your home in order to re-add all of your cameras and all of your nest devices to the new Wi-Fi network. If any of the developers could help in order to make this happen, it would be greatly appreciated, and they're also needs to be a way to get all of the QR codes for all of the cameras directly through the nest app if they've worn off the devices, that is for every single device that is on the same Wi-Fi network through nest from thermostats to security cameras!
EmptyNester
Silver Product Expert
I couldn't agree with you more and I know other people (including me) have asked for improvements in this area for years.  So far the only solution is when you replace your WIFI router that you give the new one the EXACT same WIFI name and password.  That way when it comes on-line all the devices already in place will find it and connect.
