Try Moving closer to your Nest Doorbell (battery)
kurtssmith
I am trying to install the Google Nest Doorbell (battery), and started the process and got to the part where it was actually showing a Live view of the camera on my phone but for some reason I couldn't finish the setup at the time.  So when I tried to continue it forced me to remove the device and start over.  And maybe that was the fatal flaw cause now I can't get past the "Connect to your device" step.  It keeps coming back with "Try Moving closer to your Nest Doorbell (battery)". The sad part is like I said before, I got beyond this point originally. I have even tried pressing the button at the back for 30 seconds to see if I could initiate a factory reset.  But that doesn't seem to help either.
princ3aly
Same issue!!
I performed a hard reset (small button under the charging port) and it works now
Hey Folks.
