Water drops in Nest Outdoor Camera lens area
Subbaraoch
My outdoor camera has water droplets inside the lens area. Though weather is dry they are not going off. Seems issue with the weather protecting layer.
virnab
Hi Subbaraoch,
Thank you for reaching out to our community.
I understand that your Nest Cam Outdoor has water droplets trapped inside the lens area, which are not clearing up despite dry weather. I understand your concern, and I'm ready to assist you in finding a solution.
Before we start troubleshooting further, I need to ask you a few questions:
  • What is your Nest Camera model? (wired or battery; 1st gen or 2nd gen). You can use this Google Nest Help Center article to help identify your device: Technical specs for Nest cameras and doorbells
  • How long has your Nest Cam Outdoor been working?
  • Was the camera purchased new or used?
  • Where was the camera purchased
  • Was the camera in sealed packaging?
  • Were the factory seals intact?
In addition to this information, please post a picture in this thread showing the water droplets inside the lens area of your Nest Cam Outdoor.
In the meantime, I recommend you bring your Nest Cam Outdoor inside and dry it thoroughly until all the water droplets are gone. Use a soft, lint-free cloth. Do not use paper towels, tissues or rags to clean your camera. These materials can leave lint behind and can even scratch the lens coating. After drying, place the camera outside again and check if the issue is resolved; if the issue occurs again, please let me know.
Please reply with the requested information so we can continue troubleshooting and find a solution.
Virna
virnab
Hi Subbaraoch,
Virna
