When i cconfigure zone for notification, i have no events
Gemelos
the first time i configure my Doorbell, all is good but after reset to apply new wifi connexion, when i create a new zone , i have no possibility to choice an event , because no events listing and i have message, notifications are disable
i don't know where i can activate notification ( my mobile phone android notification is up , google home notification is OK ) so i m lost for this problem.
thank you for help
@Gemelos
In the Google Home app, have you enabled recording for at least one event type under Settings | Events | Seen events?  And then enabled notifications?
Gemelos
@MplsCustomer  thanks for reply. So yes i go in settings, events, but i find i have no activate video recods , it s why i have no events, good thanks
@Gemelos
That is odd. If deleting and reinstalling the Google Home app does not fix the problem, perhaps you should contact Support:
