10-14-2024 10:02 AM
Our ring doorbell stopped working after four years. We attempted several times to restart it and re-add it to the account with no luck. Any other troubleshooting tips?
10-14-2024 12:24 PM
What doorbell do you actually have?
The Ring Doorbell does not work with the Google Nest app.
The 1st gen Google Nest Hello Doorbell works with the Google Nest app.
The 2nd gen Google Nest Doorbell indicated in your post works with the Google Home app.
You can find factory reset instructions for Google Nest cameras and doorbells here (after the "Restart" instructions):
10-14-2024 06:03 PM
We have the 1st gen Google Nest Doorbell that uses the Nest app. The light around the doorbell button is not on but the top light is solid green currently. Sometimes the top light is a flashing green. We cannot seem to get the factory reset to to work because I don't think the doorbell button is working. We are also not able to get the doorbell to connect to WiFi
10-21-2024 11:42 AM - edited 10-21-2024 12:13 PM
Hello AMint44,
Thank you so much for keeping me updated. It is a pleasure to be able to assist you.
Please follow the steps to restore your device to its original settings successfully.
Let me know how it goes.
Daniel
