Wireless camera
LEIGHAM
My outdoor wireless camera is not picking up events unless they are within 5 feet or so of camera.   I have checked the connection, battery, motion sensor is high, I didn't add zones it should pick up anything in view. I have 2 outside roughly same distance if this one isn't closer and the other has no issue. I dont know what to do.
mdr2
Is this a new problem?  Has it been working correctly up until now.
So people on this forum have ofter reported of this kind of issue when the battery cams when running on battery-only.   Just as  a test can you run an extension cord and plug it into AC power and see if it fixes the problem?
