cant connect nest flood light
scottweston052
hello
i already have a nest battery camera set up and works perfectly, i have just added a nest flood light camera, i had an electrican wire up the floodlights.
when i try to connect the camera im getting the below error
Something went wrong
try connecting again, if that doesnt work try rebooting your device.
i have done all this and still cant connect
i have also done a factory reset and still nothing
please help
Hi scottweston052,
Thanks for reaching out. I'm sorry for the delay. Please fill out this form as I'll hand it over to our team for more options. Please let me know once you're done.
It's me again! I just want to check if you managed to fill out the form. Please let us know once done.
Hi I'm having same trouble with my floodlight camera won't connect or be discovered.  What form are we filling out for this?
sorry to tell you but i when through an exhausting lengthy process with no success.
i made contact with Amazon and was resnt a replacement which connected without a problem straight away.
the camera must have been faulty
EdmondB
Hello everyone,
@Rick075, i’m sorry to hear you’re having trouble with this. No worries; we'll check this out. Just to check: What is the status of the LED light on your Nest Camera Floodlight? Have you tried doing a factory reset on your Nest Camera Floodlight? Here is a link on how to restart or factory reset a Nest camera or doorbell.
@scottweston052, thanks for keeping us in the loop, and I'm happy to hear that this has been sorted out. If you need further help, let me know.
Edmond
