doorbell
WendyU
I moved into a new house, how do I get the doorbell to my google home app?
7 REPLIES 7
Open the Google Home app, click on the plus sign (+) in the upper left corner, select "Set up device", and follow the instructions.
If your Google Nest Doorbell (Battery) was used by a previous homeowner, that person has to first remove the doorbell from their Google Home app.
Ok I I got it set up but now the doorbell does not chime inside any ideas? I tried the quiet time button but that did not help.
We have Nest Hello doorbells (where there is an "Indoor chime On/Off" option in the Google Nest app). I don't know whether there's an equivalent option in the Google Home app for the battery doorbell.
You can also check transformer compatibility here:
https://support.google.com/googlenest/answer/9247132?hl=en
Is your battery doorbell wired?  If not, it can't ring your indoor chime.
As Mpls mentioned, there is a setting in the Home app to turn on indoor chime.  It defaults to off.  This all assumes that the doorbell is in fact wired-in, and that the transformer meets the specs.   Some people don't' wire it up, and just use it as a battery doorbell.
SteveT1
Thanks for the help @MplsCustomer and @firmwaredev. It's been some time since this thread was updated. Does anyone here need assistance?
Steve
SteveT1
Hey everyone.
We haven't heard any updates from you. I'll go ahead and lock this thread. If you're still in need of assistance, feel free to start a new thread and we'll be happy to help.
Steve
