09-08-2023 05:23 PM
my brother in law installed my nest door bell gen 2 wired
i tried to change the wifi password on the doorbell and followed instructions to remove it from my app and do a factory reset so that it could be added again
now the light stays solid white and no matter how long i hold down the reset button it does not blink yellow and factory reset, the light never turns blue indicating that it is ready to add
im stuck and ready to rip it off the wall please help!!
09-09-2023 12:40 PM
I’m having the same issue, except after the light turns white, it turns green and I still cannot connect it to my google home app. It doesn’t reset. I have completely taken it off the doorway and re-installed everything, white light comes on, then green.
09-09-2023 01:26 PM
Sometimes customers have trouble getting that reset pin to stay depressed long enough for the result below:
Some customers discover their doorbells are defective and will not perform a factory reset. You can try contacting Support using the link and instructions in this post:
09-10-2023 06:33 AM
i’ve held the button for up to 60 seconds with a paper clip, i’ve never seen a yellow light. i can feel the button release when i remove pressure from the paper clip
09-10-2023 06:49 AM
The only thing I can suggest is to contact Support using the link and instructions in the post below. I've seen posts from other customers who have gotten their doorbell replaced because it will not factory reset.
09-11-2023 12:23 PM
I just want to check if you managed to see the response above. Were you able to contact our support team by following the link provided above? Please let us know if you still have questions or concerns.
I appreciate the input, @MplsCustomer.
09-11-2023 06:44 PM
i contacted support and they have initiated a replacement RMA
09-13-2023 07:05 AM
@dirtyelf, we're glad that your replacement is on its way. Let us know if you're still in need of assistance.
@Srfchik and @lhp83, how's it going? Were you able to perform the steps that MplsCustomer has shared above? In case you have an update, you know where to find us.
I appreciate the response, MplsCustomer and Jenelyn.
