iPhone Volume
baseballfant83
Does anyone know why I’m having issues on all my cameras with lowering the volume. The volumne doesn’t lower all the way down ? its only  happening on google home app. Thanks
AngryStein
Yes, I’ve been experiencing the same problem on my iPhone 13 mini.
AZguy86
This seems to be common. It’s happening on android as well within the Google Home app. It’s almost like it’s using  The internal earpiece
Matthew Sullins
EmersonB
@baseballfant83, thanks for reaching out here in the Community. To confirm, what version and type of Nest Cameras do you have? Also, could you compare if you're doing the same steps below?
  1. Open the Home app .
  2. Touch and hold your device's tile.
  3. Tap Settings .
  4. Select Audio.
  5. Under “Camera volume,” drag the slider left or right to decrease or increase the volume of your camera.
Hit this link for more information and let us know your update here.
EmersonB
Hello everybody,
I'm dropping by to ensure that everything is covered here. How's it going with your Nest Doorbell? We would appreciate it if you could share the information I’m asking above. Also, were you able to check the steps I've shared? We'd be glad to hear from you.
EmersonB
Just one final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, we would be happy to keep it open. If there's more we can do, just let us know.
