10-15-2022 02:59 PM - edited 10-15-2022 07:59 PM
One outdoor camera (that I've had for several years, the first of four) went off-line. The Nest app setup/reconnect does not show that serial number - or any other. Also tried adding it as a new camera: same issue. The Google home app tells me I have to add it through the Nest app. I have two routers in my house: I tried using both (matched on my phone). I reset routers/modems. Checked security settings. Good strong wifi signal, router 10 feet away from the outdoor camera on the same wall.
I unplugged the camera and plugged it back in. Tested outlet. Swapped camera power cord with another cam: issue is not the cord. All other devices, all other cameras, are working. I can't get this camera back online.
Since I've had it, that camera would frequently go off-line; the last time I had to reconnect it, about 4 months ago, it seemed to hold and stopped going off line all the time. Until now. Camera on. Appears no lights showing on cam itself.
10-24-2022 09:39 AM
10-27-2022 10:07 AM
10-28-2022 10:19 AM
