Hi @stdafranklin25,
Thanks for posting in the community.
I understand the frustration of only seeing notifications on one phone for your two doorbells and cameras. The alert mentioning another account is a good clue. I appreciate your effort.
Since you did a factory reset, the first step is to reconnect them to your Google Home app on both phones. Here's how:
1. Re-add the doorbells and cameras.
- Open the Google Home app on both phones.
- Tap the "+" button in the top left corner and select "Set up device."
- Follow the on-screen instructions to add each doorbell and camera again, using QR codes or setup codes.
2. Remove the device from the old account:
- The alert suggests another account might be controlling the devices. Let's address that:
- On the phone that's not receiving notifications, check if you ever shared the device with another Google account.
- If so, open the Google Home app on that phone, tap on the doorbell or camera icon, go to Settings > Shared users, and remove the other account.
3. Update apps and restart devices:
- Ensure both phones have the latest Google Home app version (check the app store for updates).
- For good measure, restart both phones and your doorbell and camera devices.
4. Notification Settings:
- Make sure notification settings are enabled for the Google Home app and for each doorbell or camera individually on both phones.
- Check your phone's notification settings and within the Google Home app itself for each device.
Please follow the steps above and let me know once you're done. Thank you.
Jorge.
