wireless doorbell
hezawiseguy
how do I charge my Nest wireless doorbell?
RXShorty
Hi @hezawiseguy
You have to use the removal tool to get it from the bracket and charge it by using the provided USB-C cable.
https://support.google.com/googlenest/answer/9252289
zoeuvre
Hi hezawiseguy,
Thanks for posting here in the Community forum. I wanted to check and see if you managed to see the information that RXShorty has shared. Also, keep it plugged in using the provided USB-C cable, and when your doorbell is fully charged, the status light will be solid white and no longer pulse.
I appreciate your help, @RXShorty
Juni
I just wanted to follow up if you were able to try the steps provided. Please let us know, as we would be happy to answer any questions you may have
Juni
Juni
Hello there,
Just checking in to make sure that you saw our responses. I'll be locking this thread if we don't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Juni
