02-03-2024 10:29 AM
Please, is it possible to connect a Chromecast with Google TV to a Chromecast Audio, so that the sound from Netflix, for example, is played through the speakers connected to the Chromecast Audio?
02-06-2024 02:03 PM
Hi sljunior,
Thanks for posting here in the Google Nest Community. The Google Nest speakers and/or displays don't support being a slave speaker or soundbar for Chromecast with Google TV. These smart speakers are home automation devices first, and speakers function second. You may witness it working for a moment as a Bluetooth speaker, but as soon as it activates its smart functions (calendar check, routines, recognizing voice queues, etc.), it loses its connection to the Chromecast device. The same is true with Chromecast Audio, not because of smart functions since it’s not a smart device, but because of its one-way communication, which is via casting. It only receives cast commands from casting sources (smartphones, tablets, laptops, etc.), and the Chromecast with Google TV has no capability to cast because it’s also a recipient of casting commands as well.
It’s best to pair a true Bluetooth speaker, which will function as a slave audio output. There’s nothing wrong with your devices; it is by design.
I hope this sheds some light on the situation. Let us know if you have other questions.
Kimy
02-07-2024 02:58 AM
Thanks Kimy for your reply.
I hope that Chromecast TV will implement casting for smart speakers in the future.
Sergio
02-07-2024 03:56 PM
Hello sljunior,
Thanks for the reply. I suggest you send feedback via Settings > Help and Feedback and include details about your request. After all, Google is big when it comes to customer feedback.
Let us know if you still have questions or concerns.
Kimy
