Internet Connection problem
Ghabcha
I have a google TV Chromecast here in Syria, I bought it from Lebanon and tried it successfully there, but once I connected it here in Syria, I got the message, cannot reach internet. I reset it to factory settings and no respond, the message is always the same.
Can anyone help me solving this problem?
Is it possible that google doesn't support its products in Syria?
Thanks.
JenniferV
Hi Ghabcha,
Thanks for reaching out. The Chromecast with Google TV isn't officially supported in Syria so its features and functionalities might not work. You may try to connect it to a mobile hotspot and check if it will be successfully connected or check the settings on your router. See the info below:
Enable these settings on your router, if applicable:
  1. Universal Plug and Play (UPnP)/Multicast
  2. Internet Group Management Protocol (IGMP)
Disable these settings on your router, if applicable:
  1. AP/client isolation
  2. Virtual Private Networks (VPNs)
  3. Proxy Servers
Note: If you aren’t not familiar with these settings, you may refer to your router manufacturer's documentation or you may contact your internet service provider for help.
Jennifer
JenniferV
How's it going? Did you manage to get your device working?
Jennifer
JenniferV
Hello Ghabcha,
Just checking in to make sure that you've seen my response. Please let me know if you have other questions or concerns as I will be locking this in 24 hours if I won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
Jennifer
