10-28-2023 12:17 PM
My remote won't stay pair between power cycles.
I've changed the batteries. I've re-paired the remote using varries methods. It works during the time I'm using it, but after I turn my tv off the remote stops working.
10-29-2023 05:13 PM
It is possible this could be addressed by https://www.googlenestcommunity.com/t5/Chromecast/Chromecast-remote-will-not-turn-on-Chromecast-All-... a firmware update which is slowly being distributed.
I don't know, but I am hopeful. I have a similar problem. More discussion: https://www.reddit.com/r/Chromecast/comments/17j5n5l/every_day_i_find_it_necessary_to_disconnect_the...
10-31-2023 06:32 PM
Appreciate your help here, @ncr100.
That’s right, @KayCee1. This may not be a remote issue but rather related to the bug that will be included in the patch fix. The bug is about the main Chromecast device not turning back on after not being used for a period of time (rest). In any case where you are experiencing issues with the actual remote, try the following:
These steps are only applicable if it's an actual pairing issue with the remote. Let us know how it goes. We look forward to your response.
Kimy
10-31-2023 06:48 PM
Thanks everyone, I'm working with Google on warranty replacement right now.
10-31-2023 06:53 PM
Hi KayCee1,
Thanks for the update. I’m glad that this has been sorted out. Feel free to create a new thread if you have questions or concerns in the future.
Kimy
