Sound
Silent1
Have used Chromecast on Soniq TV and other devices over past 3 years with no problems. However, now I have no sound with some shows within an app e.g. Prime and sound with others. This happens in other apps as well. I have checked sound settings on both Chromecast and TV and tried changing HDMI port to no avail.
JenniferV
Hi Silent1,
Thanks for reaching out. Let's sort this out.
Is the TV connected to an external receiver, soundbar, or speakers? Does the issue persist when casting from a mobile or tablet device and from the Chrome browser? Try the steps below:
  1. Make sure the Chromecast is powered on and if the TV is on the right input.
  2. Make sure the device you're using with Chromecast is not muted (Examples: TV, mobile device, etc.).
  3. Make sure that the TV, sound bar, and/or receiver is not muted.
  4. Use a different HDMI device on the same HDMI input and check if audio works.
  5. Reboot the Chromecast.
  6. Unplug the TV and plug it back in after 2 minutes.
  7. Cast the same Chromecast device on a different TV (if possible).
  8. Perform a factory reset on your Chromecast.
Let me know how it goes.
Jennifer
JenniferV
Hello there,
It's me again. I want to make sure you're all good — how did the steps go?
Jennifer
JenniferV
Hey Silent1,
Just checking in to make sure that you've seen my response. Please let me know if you have other questions or concerns as I will be locking this in 24 hours if I won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
Jennifer
