1 home multiple devices . How go i have 5 devices in one h I me?
Curlystg
How do I have more than one  device list under one home?
Cathal_S
Please have a look at the Google Nest help center link below for more information about adding devices.
https://support.google.com/googlenest/answer/9893532
Cathal
Princesss
Thanks for reaching out.
We appreciate the help, @Cathal_S.
@Curlystg, hope you find the steps helpful. You may also want to check these steps in managing your home:
Create a home
  1. Open the Google Home app Google Home.
  2. At the top, tap Add Add.
  3. Tap Create new home.
  4. Follow the steps.
Note: You can have up to 5 homes in your account.
Switch between homes
  2. At the top, tap the name of the current home.
  3. Select a new home from the drop-down. If the drop-down icon doesn’t appear, it means you only have one home in the Home app.
Move a device to a different home
​​​​​​Note: Not all devices can be moved to a different home this way. Speakers, displays, and Chromecast can be moved, but Nest Wifi point and Nest Hub Max can't. Some Nest and Wifi devices can't be moved to a different home. If you have a device that can't be moved to a different home, you need to factory reset your device and set it up again in a new home.
  2. Open the home the device is in.
  3. Touch and hold your device's tile.
  4. Tap Settings Settings and then Device information and then Home.
  5. Tap the home you want to move the device to and then Next and then Move device.
  6. If asked, tap the room you want to move the device to and then Next.
Hope this helps.
Princess
Princesss
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions, otherwise we’ll be locking the thread.
Princess
Azarco
Hey Curlystg,
Alex
