Wont connect wifi
N84
I live in uni dorms so i have to sign in so i cant setup my google home
David_K
Chromecast, Google Home and Google Nest devices don't support these kind of Wifi systems, known as captive portals, that require you to login first to be able to access the internet. There are a couple of possible solutions for this:
  1. Check with whoever manages your Wifi if they have a process to whitelist your device. They do this by allowing the unique MAC address of the device. Not all providers will be setup do this however. In addition, even this may not work on some Wifi networks, as the administrator may have enabled a security feature called client isolation, which prevents different devices from communicating with each other (i.e. your phone communicating with your device).
  2. Although unsupported by Google, you can try to use a phone or tablet as a Wifi hotspot. However, this will then use your mobile data plan, which could be expensive for you depending on the data plan you have with your carrier. Note you will need 2 devices to set this up.
    • Turn on the Wifi hotspot feature on a phone or tablet. If you're not sure how to do this, refer to the manufacturer's support website.
    • Connect a second phone or tablet to that Wifi hotspot.
    • You can then use that second phone or tablet to setup your device and connect it to the Wifi hotspot on the first phone or tablet.
  3. If you're able to use  a wired network connection instead, you could invest in your own cheap router and connect your devices to that router instead.
Princesss
Thanks for reaching out.
We appreciate all the steps you've shared, @David_K!
@N84, were you able to try the steps posted above? Let us know if you have additional questions and the Community would gladly help.
Princess
Princesss
Princess
Azarco
Hey N84,
Due to inactivity, we'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google Home speakers and we'd be glad to assist you further.
Alex
