03-03-2023 05:11 PM
I have 2 lights that seem to have been rolled into one entry and i now wish to remove one of them, but I can not gain access to that individual one. There does not appear to be an option to delete just that one connection. It wants to delete everything. I'm missing something.
03-08-2023 02:15 PM
Hi Wazza65,
Yep — that’s correct. There’s no option to unlink the lights one at a time in the Google Home app. You need to unlink the account on the Google Home app where these lights are associated with. Then, open the native app and remove the light that you don’t want to use. Once done, go back to the Google Home app and relink your account. The light you want to control should appear in the Google Home app.
Let me know how it goes.
Juni
03-05-2023 05:07 PM
How do I delete one light from room that has several.
03-11-2023 08:46 AM
Hi Wazza65,
Thanks for posting.
It seems like you already created another thread about this concern, so I'll merge this with the main post so we can communicate effectively. You can follow the main thread for updates because this one will be locked automatically once merged.
Lovely
03-11-2023 05:06 PM
Dan
03-12-2023 06:55 PM
Hey Wazza65,
Dan
