09-01-2023 09:29 AM
I am trying to build an automation whereby ADT is disarmed when I unlock the Yale-Nest lock using my keypad code. It is to work when google senses I am in the vicinity of home, and between certain hours. Everything seems ok but I get an error in the action: "The combination of optional fields in the Struct is not eligible."
This does not make sense since the ArmDisarm Struct is available for ADT.
I also tried replacing the action with an OKGoogle Command of "Disarm ADT" which does work by prompting a speaker to ask for the disarm PIN, but that is pointless if I am outside. I tried in the command "Disarm ADT; [PIN]" which did nothing.
Anyone with ideas of how to make this work?
Maybe there is a way to program my ADT disarm PIN into the automation?
What I have is below. Thanks.
metadata:
name: Yale Nest Lock disarms ADT
description: When the Yale Lock is unlocked using the passcode, and ADT is armed, ADT will disarm
automations:
# ---- STARTERS ---- #
starters:
- type: device.state.LockUnlock
state: isLocked
is: false
device: Front door - Porch
# ---- CONDITIONS ---- #
condition:
type: and
conditions:
- type: home.state.HomePresence
state: homePresenceMode
is: HOME
- type: time.between
before: 09:30:00 PM
after: 05:15:00 AM
weekdays:
- MON
- TUE
- WED
- THU
- FRI
- SAT
- SUN
# ---- ACTIONS ---- #
actions:
- type: device.command.ArmDisarm
arm: false
devices: ADT Living Room - Living room
09-09-2023 10:01 AM
I'm having the same problem.
10-25-2023 09:04 PM
Hello. Just wanted to see if you had made any progress in handling this issue? I'm running into the same thing.
10-26-2023 07:50 AM
I haven't yet.
11-22-2023 05:43 AM
Having the same problem. It's mind boggling why the ADT device in automation provides options to arm, however, for disarm, the only option is to use a text command.
11-26-2023 08:37 AM
Google: please advise. It has been nearly 3 months without a response.
01-20-2024 09:15 AM
A response would be nice! Is there a way to work around this with a text command that includes the PIN? Obviously, not ideal, but better than nothing.
