07-29-2025 02:54 PM
The way PSEG can adjust my Nest thermostats is ridiculous. Never authorized. To disallow is also totally confusing on some app that I was redirected to.
08-01-2025 12:27 PM
Hi @Budman22,
Thanks for reaching out to the community. I understand that PSEG can adjust your Nest thermostat without clear authorization and it's confusing to disable it on some app that you were redirected to. I'm happy to help you find the most accurate information.
To assist with troubleshooting, could you please provide the following information?
What type of Nest Thermostat do you have?
What app are you currently using to control your Nest Thermostat?
What is the app PSEG is redirecting you to?
I look forward to your response so we can find a solution for you soon.
Gabriela
