Automation UX removes bulb color
Outlaw26r
You can no longer change the color of bulbs in automation. This is such a step backward. At least give us the option to use the old ux if needed.
I'm assuming you are using the Early Access (beta) version of the Google Home app?
Use the old version instead
Search "Open Assistant Routines" on your phone.
