Bosch smart home water sensors not compatible
Zeeburg
Why is it not compatible with google home
2 REPLIES 2
Alex_S
Hi Zeeburg,
Thanks for visiting the Google Nest Community. A few questions: what’s the model/version of your Bosch smart home water sensor? Does it say on its box that it works with Google Assistant? What is the native app you’re using for it?
I’ll look forward to your response.
Alex
Spenque1
I don't have any water sensors.  I looking for a product that will with my home app
