Changing router & wifi
Griff1982
I need to upgrade my BT router and therefore my network. If I just move my google speakers to the new network will I have to re-configure all smart devices such as plugs & bulbs or will they automatically migrate?
David_K
If you change the Wifi network name and password to be the same as your previous Wifi network, all your devices will automatically connect. If you don't, you'll need to follow their steps to change the Wifi network on them.
David_K
Just wanted to say thanks. This took minutes other than hours!
chips994
Where do I find the steps to change the wifi network on my devices. none of them are working on my new router
