10-26-2022 12:26 PM
Hi there. The remote on my iOS device is greyed out, but my Chromecast is up to date, please assist.
11-03-2022 06:52 PM
Hi Bhekzen,
That certainly hasn't been easy for you ― let’s check this out. Was it working before with your Chromecast with Google TV?
Reboot your WiFi router and Chromecast. Restarting the phone also helps. If needed be, use a different HDMI port and see what happens to the link between your phone and your Chromecast. Reinstall the voice remote. Also, this link will give you more information and troubleshooting. Follow it up with this guide.
If you’re having trouble getting the virtual remote to work properly, make sure that you have the most recent versions of the following apps:
Keep me posted.
Dan
11-07-2022 10:14 AM
Hello again,
I wanted to follow up and see if you are still in need of any help. Have you had the chance to try the suggestion above? If yes, how is it?
Dan
11-07-2022 10:16 AM
Hi again,
Dan
