Compatibility with Lennox furnace G8Q3-90-4
JoaoCarvalho
Does anyone know if the Nest Thermostat is compatible with the Lennox gas furnace model number G8Q3-90-4?
The wires connected to my current thermostat are connected to the W and Rh connectors.
I wanted to follow up and see if I could be of any help. You can use our compatibility checker to enter the wires you are seeing. It will then let you know if the system is compatible or not. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
