Connecting a Lenovo Smart Clock Essential
NewUserinMaine
My Google Nest Mini is not “finding” two devices;  (1) the C smart plug (included in the Google nest package).  (2) a Lenovo Smart Clock Essential.
How do I get my Nest Mini to “find” these 2 devices?  Thanks!
8 REPLIES 8
Azarco
Hey NewUserinMaine,
Thanks for reaching out. Make sure your devices are connected to the same network and within 15-20 feet of your router.
For your C Smart Plug, give these steps a try:
  1. Turn the device off for 10 seconds then turn it back on.
  2. Make sure you have the latest version of the Google Home app.
  3. Reboot your speaker or display.
  4. Force close the Google Home app.
  5. Factory reset your speaker or display.
  6. If your plugs still don’t show up in either the Google Home app or the Cync (C by GE) app, try resetting them as well.
Let me know how it goes.
Alex
I am covering my lenovo smart clock essential with google home. After entering the Wi-Fi password it shows can't communicate with the device and comes back to set up window
Azarco
Hey Jindalyogesh,
To be clear, are you setting up your Lenovo Smart clock using the Google Home app? Are you also setting up a Google Home speaker? If you're having problem connecting your Lenovo device to your network, try resetting it or contact Lenovo support for assistance.
Kind regards,
Alex
Azarco
I wanted to follow up and see if you are still in need of any help? Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Alex
I have the exact same issue.  My Lenovo clock will not connect.
Azarco
Hey Carolinagirl,
Have you tried the suggested steps above? Let us know if you have tried it, if the issue persists please contact Lenovo support for further assistance.
Alex
Azarco
Hey Carolinagirl,
Alex
Azarco
Hey Carolinagirl,
Just checking in to make sure that you saw my response. I'll be locking this thread if we won't hear back from you again in 24 hrs. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Kind regards,
Alex
