11-23-2023 05:33 AM
I added a light switch via one of my 'works with google' accounts (Abode). I added the switch to my home and to a room. The switch appears in settings correctly under Devices, Groups, and Rooms, showing the room. The switch appears in the Lighting button from the Favorites page correctly, under the correct room. It does not appear on the Devices page at all. Not sure why. I have relinked Abode and it did not change anything.
Thanks!
11-29-2023 04:16 AM
Hi Jeff86,
Thanks for posting—let's get this sorted out. Try to uninstall and reinstall the Google Home app > Command Google Assistant to “Sync my devices”. If it shows the same behavior, try using a different device and installing the Google Home app. Let me know how it goes.
Alex
11-29-2023 01:19 PM
Uninstalling/Reinstalling the app did not work.
11-30-2023 11:36 AM
That’s odd. What’s the iOS version of your phone? Do you have a spare phone or tablet? Kindly check if using a different device does the same behavior.
Alex
12-01-2023 06:24 PM
Hi, I have version 16.6.1
It does not show up in Devices on the other phone in my household either. It does show up in settings as it should.
12-12-2023 10:09 AM
Hello Jeff86,
Apologies for the late reply.
We appreciate all your efforts. We'd like to take a deeper look into this for you. Please fill out this form with all the needed information, and then let us know once you're done.
Warmly,
Alex
12-14-2023 10:12 AM
We haven’t seen your form submission come through—were you able to access it alright? Let us know if you’re running into trouble or still need our help.
Alex
12-14-2023 11:24 AM
Hi, I did end up moving the device to another room and it showed up there. I moved it back and it did not show up as expected. I left it in the room where it worked.
12-15-2023 10:46 AM
Ah! I’m glad that you were able to find a resolution for this. Thanks for the update. You can always send us feedback on how we can improve the Google Home app. Let me know if I can help you with anything else on Google Home.
Alex
03-10-2024 04:31 PM
I am having exactly this issue. Only shows up in devices when moving to another room. For me it's a Tapo outlet.
