Does a Google Wifi router work as inner mesh node behind a Nest Wifi router?
pkerchnerP
If not, why not?
Google Wifi routers are the same hardware as a Google wifi access points?
Google Wifi is interoperable with Nest Wifi and vice versa?
My google Wifi router requires to be connected to a  Ethernet cable and does not recognize the main nest wifi router.
Google / Nest Wifi is fool safe?
David_K
Speed answers to your questions 🙂
Yes.
Yes, whether you use a Google Wifi device as a router or point, it's the same hardware.
For the most part yes, details here:
https://support.google.com/googlenest/answer/9548099
Is that a screen you're seeing in the Google Home app? If you have already set up a Nest Wifi network, you should be able to add Google Wifi points by following the steps to add a point to a Nest Wifi network.
pkerchnerP
Sorry, for my installation it did not work  -
I spent like 4 days testing on it.
Google Wifi Router as master node with trying Nest Wifi Router as inner mesh node and vice versa.
Doing a lot of factory resets on almost very component (ok, no reset of nest mini, nest and other speakers)
I probably got European components, that seem not really mature and tested - even with having a done firmware updates.
An quite frustrating experience having it send back to seller . Price for Google Wifi Router is on the limit (70€) - Nest Wifi Access Point with 130€ being too expensive. Moving now to Xiaomi
Azarco
davidking, we appreciate you for answering those questions.
pkerchner, we're sad to see you go. We're here if you change your mind and if you have additional questions with your Google Wifi or Nest Wifi devices.
Kind regards,
Alex
Azarco
Hi pkerchner,
I wanted to make sure and see if you are still in need of any help. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Alex
Azarco
Hello pkerchner,
We haven’t heard any updates from you. I’ll go ahead and lock this thread in 24 hours. If you still need assistance, feel free to start a new thread in the Community and we’ll be happy to help.
Alex
