08-14-2024 10:31 AM
I have an existing Nest Doorbell wired that has worked great, so I decided to buy one for my other door. I bought a Nest doorbell wired gen2 for the second door. Now our chime buzzes and rings sporadically on its own. Do I need to install a puck for the gen2 unit? If so, where can I buy one? Thanks in advance.
08-14-2024 11:04 AM
Each Google Nest doorbell needs its own chime puck/chime connector. The one for the 2nd gen Google Nest Doorbell is different from the one for the 1st gen Google Nest Hello Doorbell, and has 2 wires instead of 4. There should be a chime connector included in the box with each doorbell; you can't buy them separately.
I'm just another Google Nest customer. If your doorbell came without a chime connector, you could try contacting Support about a replacement:
