Durchsagen werden nur geschrieben
DirkRa
Moin,
Meine Nest 2 Geräte bringen Durchmesser nur geschrieben weiter! Wie kann man das ändern?
2 REPLIES 2
tajennifer
Hi DirkRa,
Thanks for posting. I understand that your Nest device is just showing diameter, and you want to change that. Don't worry; help is here. I just need to ask for some information to provide the best help:
  • What Nest device do you have?
  • What is the reason that you need to change the measurements?
  • Can you please explain to me more about the situation that you are facing?
Please keep me posted. I'll be waiting for your response.
Jenny
Moin,
Es sind Nest 2 Geräte! Ich will es hören, da es nicht in Sichtweite ist! Durchsagen möchte ich hören, nicht lesen! FUCHSIA 24202410091032300
