08-27-2022 02:50 PM
08-31-2022 03:33 PM
Hi ianlandmon,
Thanks for reaching out. I'm sorry to hear that you're having an issue with connecting your Echo Dots. Upon checking, it supports both 2.4 GHz and 5 GHz bands. Are you getting any messages when you try to connect your Echo dot?
Edward
08-31-2022 04:00 PM
No messages in the Alexa app. Just following directions. It asks to connect to the Echo's signal and then select which wifi is supposed to connect to, enter password, then it goes back to "connect back to the Echo's signal" even though I'm still connected to it. Tried multiple phones, factory resets, power cycles, logged out off app, uninstalled app, reinstalled app. It might just be a dud. Amazon support says it should work but because I can't split the wifi, it won't connect to the network, like it doesn't know which band to choose. It's not a deal breaker, the echo was a gift. Maybe a regift, maybe because it no workie.
09-01-2022 09:27 PM
Hi ianlandmon,
Thanks for the response. One thing that you could also try is to set up a mobile hotspot using the same SSID and password of your Google Wifi, and try to connect your Amazon Echo to it. Once connected, disable the hotspot and check if your Echo would connect to your Google Wifi.
Edward
09-05-2022 05:24 PM
Hi ianlandmon,
Edward
09-05-2022 07:33 PM
09-06-2022 07:38 PM
Hi ianlandmon,
Thanks for the update. I'll keep this open until you get the chance to try it. Keep us posted.
Edward
09-09-2022 07:41 PM
Hi ianlandmon,
I'm checking back in. How's it going with your Google Wifi? Still need our help?
Edward
09-12-2022 08:42 PM - edited 09-13-2022 09:35 PM
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google Wifi and we'd be glad to assist you further.
Princess
