09-06-2024 07:40 PM
Hi
I have a Google Home mini 1st Generation (H0A) was working fine, then one day just wouldn't turn on, no LEDs come on. I have tried different power supplies and power sockets, power supply is fine and so are sockets. I have followed the instructions to factory reset, but that doesn't work. No matter what I do, I can't get an LED's to turn on.
Have tried the flicking the mute button on and off, but doesn't seem to do anything either
Any suggestions google?
09-09-2024 05:13 PM
Hi there!
Thanks for posting in the community.
I’m sorry for the inconvenience that this Nest Mini may have caused you. I understand that when you are performing the factory reset on your device, it is unresponsive. Let’s troubleshoot your device together. In order to confirm that we have followed the correct steps to factory reset your device, here I send you the steps:
If after following those steps your device is still unresponsive, here are some additional troubleshooting steps that might be helpful:
Please check the following articles: Issues when you reset your Google speaker and Factory reset Google Nest or Home speakers or displays.
Tell me how it goes.
Daniel.
