Google Home mini speaker won't strat alarm dismissed routine if it was done by touch
the-one
Hi, I recently bought Google Home Mini speaker. I have set up a morning routine which is triggered after alarm is dismissed. But it only works if I dismiss the alarm vocally by saying "dismiss the alarm". If I touch the speaker to dismiss it, the routine won't start.
Any way to fix the issue so I can start routine after touching speaker to dismiss the alarm?
Azarco
Hey the-one,
Thanks for reaching out — let me help you with your routines.
A few questions: are you using ready-made or custom routines? Did you set a trigger word for your routines? To have a clear view, can you take a screenshot of your morning routine? If your Google Account is visible, please edit it out.
Keep us posted.
Alex
Dan_A
Hi the-one,
Have you had the chance to check our responses? If you have other questions or concerns let us know since we will be locking this thread in 24 hours.
Dan
Dan_A
Hi the-one,
Dan
