05-22-2025 10:59 AM
Hey all,
I’ve noticed some odd behavior on iOS 17 when switching between the Google Home app and the scarlet iOS installer. After using Scarlet, some of my Nest automations either delay or don’t run as expected.
Not sure if it’s a background process issue or something about how Scarlet interacts with local network permissions. Has anyone else seen similar conflicts when using third-party apps outside the App Store?
Would appreciate any insights. Thanks.
05-25-2025 05:56 PM - edited 05-26-2025 01:43 PM
Hi yvonne45778,
Thanks for your post. I understand you're experiencing delays with your Google Home routines and that your automations aren't running as expected, particularly after using the Scarlet iOS installer. I'd be happy to provide some guidance.
We only recommend using your Google Nest devices in conjunction with the Google Home app. This helps ensure optimal performance and smooth execution of your automation sequences.
I hope this helps!
Jenny
05-26-2025 12:13 AM
Scarlet, being a third-party installer, may interfere with system-level settings or network configurations that Google Home relies on for smooth operation. To troubleshoot, try restarting both your iOS device and Google Home, check your Wi-Fi stability reiki training, and ensure all app permissions are correctly configured. If the issue persists, consider uninstalling Scarlet temporarily to see if the delays are resolved.
07-27-2025 09:16 PM - edited 09-20-2025 05:39 AM
It’s possible that the delay in Google Home routines after using the Scarlet iOS installer is due to how it affects system background processes or network connectivity. Some third-party tools can interfere with smart home automation timing.
If you’re using streaming apps like Netflix, YouTube, or even Nekopoi—which is surprisingly smooth and efficient in content delivery—you might notice that only certain services are affected while others like Nekopoi anime streaming app continue running flawlessly. Try restarting your device, re-linking Google Home, and testing routines again. Temporarily disabling Scarlet may help pinpoint if it’s the cause without impacting trusted apps you rely on.
07-29-2025 12:47 AM - edited 07-29-2025 12:47 AM
Hey, I’ve seen similar behavior but in my case with a streaming app I sideloaded via Scarlet. After running it for a while, AirPlay casting to Apple TV would intermittently hang until I force-quit the sideloaded app.
It seems like Scarlet-installed apps may not always release local network permissions cleanly, which could explain conflicts with Nest automations too. iOS 17 tightened background process handling, so if the sideloaded app keeps a network session alive in the background, it might delay or block other services.
One workaround I’ve tried is disabling Background App Refresh for Scarlet and the sideloaded app — that reduced the conflicts quite a bit. Might be worth testing whether your automations behave better with that toggle off.
08-04-2025 01:23 AM - edited 08-04-2025 01:35 AM
Hey @yvonne45778, good question! I’ve seen something similar on iOS 17 too — especially after using apps like Scarlet and even some third-party photo editors that aren’t from the App Store. It seems like iOS can get pretty strict with background processes and local network permissions when it comes to sideloaded apps, and that can spill over into delays with Google Home routines and Nest automations.
What helped me a bit was going into Settings → Privacy → Local Network and double-checking that Google Home, Scarlet, and any photo editing apps I sideload have local network access enabled. Also, making sure Background App Refresh is turned on can sometimes help keep everything running smoothly.
Would love to hear if anyone else found a cleaner workaround — especially those using creative tools outside the App Store!
08-14-2025 01:45 PM
I’ve tried many streaming apps, but Magis TV for PC is on another level. Smooth performance, HD clarity, and an endless choice of movies, shows, and live channels—perfect for non-stop entertainment.
08-19-2025 08:49 AM - edited 08-19-2025 08:51 AM
Interesting observation! Background process conflicts can definitely create unexpected issues, especially when multiple apps are trying to manage network permissions. I’ve seen something similar, not with iOS, but when relying on LESCO’s online bill system. Sometimes if the official site is slow or a third-party portal isn’t properly optimized, it causes delays in fetching bills or due dates — almost like the automation issue you’re describing here. It makes me wonder if Scarlet is interfering with how Google Home processes local data, the same way a poorly tuned online billing tool can disrupt smooth access. Maybe checking network permissions or isolating the apps could help narrow it down. Check Your Bills here-> https://lescoebil.pk
08-23-2025 01:51 AM - edited 08-23-2025 01:53 AM
I’ve tried many editing apps, but CapCut Pro Mod [https://capkutpro.com] truly stands out. The unlocked tools, pro filters, and premium transitions give my videos a cinematic look without spending hours on edits. I especially love that all the premium features are available for free—templates, fonts, and effects that usually cost money are right at my fingertips. It’s a perfect choice for beginners and advanced editors alike who want professional-quality results. This is a must-download!
09-23-2025 10:31 AM - edited 09-23-2025 10:32 AM
Vedu is an absolute game-changer for anyone who loves movies and TV shows! The app doesn’t just stream content in flawless HD quality, it also ensures there are no annoying ads to interrupt your viewing experience. Its interface is clean, simple, and easy to navigate, making it perfect for both casual viewers and true binge-watchers. https://vduapkdl.com/
10-05-2025 06:05 AM
Magis TV is an online streaming app that offers users a wide range of high-quality premium content. It works on multiple devices, including Smart TVs, Android TV boxes, TV sticks running the Android operating system, and Android TV.
11-03-2025 10:45 PM - edited 11-05-2025 05:13 AM
Yeah, I’ve run into something pretty similar on iOS 17.1 — not specifically with Google Home, but with HomeKit automations acting weird after I’d been using apps installed through ScarletiOSStore. My guess is that iOS gets a bit defensive about background refresh and local network access when it detects unsigned or enterprise-installed apps.
In my case, some automations would trigger with a 10–15 second delay, and a few just wouldn’t run until I force-closed the third-party app. I ended up re-checking permissions under Settings > Privacy & Security > Local Network and making sure both Scarlet and Google Home had access toggled on. That seemed to help a bit, though the delay didn’t disappear completely.
It might also depend on how Scarlet handles app sandboxing. Since it’s technically sideloading, it could be messing with how iOS prioritizes background tasks. Curious to hear if anyone’s found a more consistent workaround — maybe adjusting Background App Refresh or resetting network settings?
2 weeks ago
Absolutely loving Snapchat Plus APK! The premium-style features, advanced controls, and unique customization settings make it stand out so much. It’s super easy to use, and the added flexibility makes snapping and chatting way more enjoyable. Definitely one of the best upgrades out there! https://snaplusapk.com
2 weeks ago
Xuper TV stands out because it offers premium-style content without the heavy data usage that most apps require. The latest version of Xuper TV APK 2025 works perfectly on my Android TV Box and even on older phones. For anyone searching for a free IPTV app with stable servers, this one performs better than expected. The movie sections, sports channels, and Spanish content all stream in high quality with almost no buffering. Great option for people wanting a reliable all-in-one streaming APK for live TV, movies, and sports.
a week ago
Wink mod version Video and image editor video quality far better than I expected. Even low-light or shaky clips become clearer and more vibrant after editing. It’s definitely one of the best apps for improving footage instantly.
Monday
A lot of people join general solo travel or backpacking groups, and honestly it feels a bit like Jujutsu Kaisen Season 3’s Culling Game 😄 — different travelers from all over, sharing tips, forming temporary alliances, and helping each other survive routes, budgets, and plans.
Monday
Think of it like Jujutsu Kaisen Manga once a new rule gets introduced into the system, everything else has to adapt. Scarlet adds “new rules” at the OS level, and Google Home routines sometimes lose priority in the chaos.
