Google Nest as assistant and speaker - not as wifi-unit
MrMoesgaard
Hello.
I've recently given up on the Google Nest as a wifi mesh - keeps loosing connection and is just a pain in the B to get to work together.
However, I want to use them as just the speaker and google assistant, but without being a mesh/wifi unit.
What is the easiest way to come about this? Can I do it with the excisting setup or do I have to factory reset the entire bunch and add them in some way?
I hope this is the correct forum to ask for this kind of advice 😄
Juni
Hi MrMoesgaard,
This is not the experience that we wanted you to have, let me help you out. I understand that it is a good feature to use with your Nest Wi-Fi but this is not available at the moment. Could you tell us more about the issue that you are experiencing? Do you have a modem and router combo? What’s the color of the light on the parent point? Does the device LED switch from orange to teal (or white) continuously?
Check this link for more information
Hope this helps,
Juni
Azarco
We wanted to follow up and see if you are still in need of any help. Let us know if you are still having any trouble from here, as we would be happy to take a closer look and assist you further.
Alex
Azarco
Hello MrMoesgaard,
One quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need assistance, feel free to start a new thread in the Community and we’ll be happy to help.
Alex
