11-13-2023 05:02 AM
Hi
I have a Google battery doorbell, its approximately 2 years old now. After a full 5 hour charge it lasts approximately 24 hours before going completely flat. I have tried restriction motions video time length and even factory reset and still the same. Is this a common thing when they get past a certain age, thank's
11-18-2023 02:22 PM
Hi TWS1000,
Thanks for reaching out here in the Community. Battery life will depend on factors including activity, temperature, and selected camera settings. You can extend the battery life of your Nest Camera by adjusting video quality, length of video clips, time between recorded events, and using activity zones to monitor specific areas. Here are some typical scenarios.
Nest Doorbell (battery)
Give these steps a try:
Change settings to save battery
Lower the battery usage
When you lower the battery usage, your Nest Camera or Nest Doorbell will adjust video recording settings to do the following:
Here's how to lower the battery usage:
Use the battery saver
When the automatic battery saver is enabled, your Nest Camera or Nest Doorbell will automatically adjust its features to help conserve battery.
Here's how to turn on the battery saver:
To learn more, you may visit our public article about “Save battery for Nest cameras and doorbells”.
