Google speaker not connecting to WIfi
Sam10
I recently used to a new apartment and I am trying to set my google speaker. I am trying to connect it to the new wifi but keeps telling something went wrong. To note that I reset my speaker and turned off the wifi but nothing is working. Help please!
Azarco
Hey Sam10,
Thanks for reaching out — let's check this out.
To confirm, are you using a private network? If so, do you have a dual-band router? Make sure your devices are within 15-20 feet of your router.
Give these steps a try:
  • Reboot your router and devices to refresh your connection.
  • Make sure your Google Home app is updated.
  • Check router settings. (AP isolation must be disabled and UPnP must be enabled).
  • If you're using an iOS, turn on Local network access for the Google Home app. Here's how: Privacy > Local Network > Google Home app.
  • Use a mobile hotspot to set up your devices (To isolate the issue).
Hope the steps help!
Alex
Azarco
Hey Sam10,
Checking back in to see if the troubleshooting steps shared help. Let us know by updating this thread, and the community will be happy to lend a hand.
Alex
Azarco
Hey Sam10,
I haven't heard from you in a while so I'll be locking this thread in 24 hours. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Kind regards,
Alex
